Flash remote
Posted by: Bosh on 08 December 2018
My Flash 2 remote died in a cloud of smoke a few weeks ago and my local dealer says it cant be serviced anymore
I also have a Flash 1 and was of the understanding that the 2 is only a software upgrade of the 1. Does anyone know if this can be done just by swapping in the Eprom from the 2 into the 1 or does it involve more than that
Failing this which Naim remote controls both CD players and amps (my Qute 2 one does the amp but not CD555)
Posted on: 08 December 2018 by Richard Dane
Yes, it should just be a case of swapping the PIC chip. Take ESD precautions and use a proper “picker” as the chip is in very firmly and you don’t wAnt to risk damaging anything.
Posted on: 08 December 2018 by Michael
I swapped the chip from one of my Flash remotes  to another and it worked fine. Observe the precautions Richard has stated.
Posted on: 09 December 2018 by douglas
My original Flash died some months ago. Salisbury confirmed it was no longer repairable. Its my favourite Naim remote so I trawled around a few dealers and discovered that Grahams in north London had one lying in a drawer which had never been used. They offered it to me at a good price. It dates from March 2005 and works just fine. When/if it dies that will there are no more. I was just lucky. Sometimes happens.
Douglas.
Posted on: 09 December 2018 by davidf
My flash started suddenly rapidly turning up the volume. I changed betteries and same thing happened. Frightening when this happens.
anyone know what causes this to happen and how to fix?
obviously have not used it since
david
Posted on: 09 December 2018 by Richard Dane
Could be worthwhile stripping down to see if there’s something stuck under the volume pressure pad. Otherwise, Naim service might know.
Richard, tried cleaning the Flash- same thing happened- volume rapidly ramped up after just pressing the volume up bottom. I give up.will stick with my basic Naim remote. Too bad as the Flash has a great feel and heft. Any other ideas?
david
David, no idea I'm afraid.  Mark R at Naim might have a better idea - or else one for Naim service to provide some suggestions..
