Spotify on the Muso
Posted by: W12 on 17 December 2018
Hello, I have a ne Muso which is connected to my home network via wifi.  I can play internet radio through it and have also downloaded the latest update.
When I open Spotify in the Naim app (Ios) it says no track playing.  I can't see a way to log in or play my Spotify premium account in the Naim app.
Any suggestions?  I can only play Spotify via bluetooth at the moment.
As an aside I have exactly the same problem on my Naim 272
Posted on: 17 December 2018 by hungryhalibut
If you open the Spotify App you will then be able to send the music to the Muso or 272 using Spotify Connect. You don’t control Spotify directly from the Naim App. You’ll need to enable the Spotify input on the 272.
Posted on: 17 December 2018 by W12
ah i see, so you can only play spotify on the muso via bluetooth.. thank you hungryhalibut
No, that’s not what I said. You use Spotify Connect, which sends the music direct from the Spotify server to the Muso without it going through the iPhone. You have to press the Spotify Connect button in the Spotify app.
