Dropouts on MU-So after update
Posted by: dubya on 17 December 2018
Hi as per title , I’m now getting constant dropouts on radio & tidal
after the recent update, when previously it was very stable.
Is there a fix to sort this fault?
thanks
Posted on: 17 December 2018 by PG
No help I know, but since the update I have experienced no issues on the radio side of things, don't use Tidal.
Might be worth just checking your network to make sure all is in order there.
Posted on: 17 December 2018 by Simon-in-Suffolk
Have you tried using the Tidal iOS app and streaming using Airplay... I have used the Qobuz iOS app and Airplay on my Qb, and I have not had one single dropout...
