How do I re-name digital inputs on an NDX 2
Posted by: Zipperheadbanjo on 17 December 2018
Surely there is a way to customize the name of the digital inputs on the new Naim streamers. I can't find any reference in the manual. Can anyone provide some direction?
Posted on: 17 December 2018 by hungryhalibut
If it’s like the old streamers you just click on the input name under input settings.
Posted on: 17 December 2018 by Clive B
As HH says. In the Naim app choose Settings, Input Settings. Then select the input you wish to rename and click on its given name and overwrite with your chosen name.
Whilst you’re at it, you can also take the opportunity to disable the inputs you don’t need and these won’t then clutter your home screen.
Posted on: 17 December 2018 by Zipperheadbanjo
Thanks for the feedback.. I'd been trying re-name the inputs from the home screen on the NDX2 itself as opposed to from within the app.
