Subwoofer for Nova
Posted by: John L F on 21 December 2018
I’m thinking of adding a subwoofer to my Nova, Dynaudio Special 40 system and wondered if anybody had experience of using XTZ and BK subwoofers.
Reviews favour the XTZ 10.17 but I’d be grateful  for any information.
I'm not certain a sub would improve my system but would be appreciative of any user opinion.
Posted on: 21 December 2018 by Pev
I use a Velodyne sub with my Nova and N-Sats and couldn't be happier with it. As well as being easy to connect to the Nova (see thread on REL!) it comes with kit that enables you to sit at the listening position with a microphone (supplied) and view all kinds of info on your TV screen. Using built in test tones you can integrate it perfectly with your system in your room by using the supplied remote control.
Check out reviews etc. on line. Best of all it cost me £500 used!
