Airplay 2 - Naim Nova
Posted by: Leon Wadsworth on 23 December 2018
Hi there kind folks. I am hoping someone can advise whether airplay 2 is available for Uniti Range yet? My nova has no option to multi room via airplay despite being on software version: 2.6.1.9794?
My Muso is fine and has the multiroom option but nova does not.
Any help on this will be kindly appreciated.
Thanks and best regards
Leon
Posted on: 23 December 2018 by Hanover33
Not yet
Posted on: 24 December 2018 by Leon Wadsworth
Hanover33 posted:
Not yet
That is most disappointing.
Posted on: 25 December 2018 by Hanover33
It's does seem to take Naim a bit of time to update software but since the Muso Airplay 2 update came out it probably won't be too much longer.  For reference, they announced in May that Airplay2 was coming.  Also, if you can't wait, there is a nice solution from Rouge Amoeba available for Mac and PC which allows for multiple airplay streams and even to mix airplay and chrome cast streams - I have been using this for a few  years  with  very good results.
https://rogueamoeba.com/airfoil/
