Tidal can’t play
Posted by: Tariqv on 28 December 2018
Hello, my Tidal suddenly stopped being able to play anything, when I press play it just cannot. Anyone that might know the solution by chance?
I’ve tried rebooting my NDX to no avail.
thanks
Posted on: 28 December 2018 by David Hendon
Did you try rebooting your router?
If not then turn off the NDX and the router, then turn the router on again and let it fully restart before turning on the NDX. Then I would stop and restart the Naim app too.
best
Posted on: 28 December 2018 by J Saville
Try loggin out of Tidal in the Naim app and logging back in.
App > Settings cog > Input Settings > Tidal
Posted on: 29 December 2018 by Mike1951
There is a problem with Tidal/NAIM streaming according to CS.
Tidal have made a software change that causes a playback problem and NAIM are currently developing their way out of it.
Should be corrected “early next year”, apparently...
Posted on: 02 January 2019 by Chris Paling
Anybody hear any developments on this? Tidal will play a track but will not play continuously (again).
