Biamping two Nap 140
Posted by: Pierre2LR on 01 January 2019
Hello!
For a long time, I have had a Nac 72, a Nap 140 and a pair of Jean-Marie Reynaud loudspeakers.
Recently, I have had the opportunity to buy a pair of Davis loudspeakers.
Now that I have got four suitable loudspeakers, I am thinking of buying a second Nap 140 to be able to use these four loudspeakers simultaneously.
Is it really possible to use two Nap 140 together with a Nac 72?
Do you think it is worth it? Could you advise me, please?
Pierre2LR
Posted on: 01 January 2019 by james n
I'm not sure how good that setup would be but...
You'd need a Hicap to power the 72. Output 2 to one 140, Output 3 to the other.
Alternatively, you could do it with a custom made Y cable and no Hicap but if you need to ask how...
Posted on: 01 January 2019 by Richard Dane
I would not want to be using two sets of speakers simultaneously in a 2 channel stereo system.
You can certainly use two NAP140s to passively bi-amp a pair of speakers (should they allow bi-wire/bi-amp connection), but as James says above, you'll need to have a Hicap powering the NAC72.  The Hicap provides the 2 pairs of stereo pre-amp outputs required.
However, you may well wish to consider just what you want to achieve before making the next move.
Posted on: 01 January 2019 by Pierre2LR
Thank you all for your advice.
I think that first I am going to purchase of a Hicap to power the Nac 72. (I should have done this a long time ago!)
Good plan
