Uniti Star still thinks it is playing a CD
Posted by: Fenderman on 10 January 2019
Hello. I am new to the forums and new to streaming etc. I seem to have a new problem with my star. A couple of days ago after playing  a CD (and ejecting it of course!) I switched back to a radio station and the radio station artwork/name would not appear in the Stars display. Since then no album artwork from ripped CDs, internet radio or Tidal will display. Just a blank CD screen. Anyone else had this problem? If so how did you fix it? I have tried turning it in and off again but didn't fix it. It plays all the formats with no problem...just can't get rid of the CD screen.
Posted on: 10 January 2019 by Chris_T
I have found that the occasional glitch like that with my Star seems to be solved by powering down, unplugging, plugging back in and restarting. If that doesn't work, perhaps going  through the setting up procedure again might do the trick
Posted on: 10 January 2019 by Fenderman
Thank you Chris. Did as instructed and all restored to normal!
Glad to help
