HDX and wifi
Posted by: Svital on 19 September 2011
Hello,
My HDX is connected to my NAS using wifi.
I can not read HD Flac audio tracks (24/96) : music is stopping, restarting, ... Does anybody who uses wifi have same problems?
Many problems occured when those files were "added" to the HDX music library: bad genre or cover art, ... How Can I rebuild the correct music list?
Stéphan
Posted on: 19 September 2011 by Paul Quigley ie
Wi Fi is not recommended for the HDX.   The band width is too limited.   Go for the CAT-5 / CAT-6 option.
Posted on: 19 September 2011 by Svital
What is the HDX ethernet speed : 10/100/1000?
Posted on: 08 October 2011 by sktn77a
It's 100.  Theoretically, a well functioning G network should give you about 20-25 Mbps..  I'm using the Netgear WNCE2001 with a weak wireless G signal and it's streaming internet radio (Paradise 320) just fine.
Posted on: 09 October 2011 by Svital
I installed 1.6, and tried internet radio. Paradise and others 320K ones work perfectly, using wifi.
But i still have the same problems listening to flac 24/96 files on my NAS...
Stéphan
