Connect hicap2 to nac 82
Yup, as per the manual illustration.  Hicap to NAC82 via SNAIC5 (banded end of SNAIC closest to NAC82).  Then take pre-amp signal from the Hicap to your power amp.  Make sure you have the NAPSC connected to the NAC82 and powered up, and that the 5 pin link plug for Upgrade 2 is fitted.
So you have got yourself a 82, enjoy as it's a good pre
Anyway here you go
Looking at the back off each unit
On the 82 on the left had side are 3 pots in a row on the top with one below and next to that the napsc
Top left on 82 to right port on 1st hicap 5 pin to 5 pin
Top right on 82 to right on second hicap 5 pin to 5 pin
Then on the first hicap you use the next pot to the one you have connected the 82 too and that goes to the power amp
Hope that helps and enjoy
Add Reply
Likes (0)
