Improving performance NAC-N 172XS/NAP 155
Hi everyone.
I have the NAC-N 172XS/NAP 155 into Sonus Faber Concertino speakers.
Speakers:
System: 10 liters two-way bass reflex
Nominal Impedance: 8 ohms
Power Handling: 25-120 watts
Frequency response: 55-20,000 Hz, + 3 dB
Crossover: First order attenuated
Sensitivity: 86 dB/1 watt/1 m
Drivers
Woofer/Midrange: 140 mm PP treated cone
Tweeter: 20 mm silk dome ferrofluid
Connection: Bi-wiring
Dimensions (H × W × D): 320 × 220 × 290 mm (12 × 8 × 11 in)
Packaged Weight: 33 lbs. (15 Kg)
I find I need to push the volume high to get the detailed Naim signature sound.
My dealer suggests swapping out the NAP 155XS for a NAP 250.2 (non DR) to solve the problem, rather than the 272XS streamer (do that later).
Any suggestions?
Original Post
Based on feedback I upgraded the NAP-155xs to a pre-owned NAP250.2 and a pair of new NACA5 cables.  The NAC-172XS NAP205.2 combo is now singing sweet tunes through my much loved Sonus Faber Concertino speakers. The upgrade is spectacularly different in all positive ways.  I instantly heard the improvement in soundstage, separation, musicality....and just pure enjoyment.  The speakers had air and room to operate.  I am very pleased, to say the least.
My local dealer is now offering a pre-owned NAC282/flatcap to work with the NAC172 with a view to swapping out the NAC172 for a pre-owned NDX or NDX2 at a later stage. I could also keep an eye out for a pre-owned hicap.
Thoughts on this upgrade path?
Good to hear that you are enjoying your amp upgrade. A 282 would be a step towards a great system, although I would consider looking for a Hicap to power it rather than a Flatcap. Running this with a 172 as source will work, but I don’t know how good it will sound into a superior amp. Another option would be to upgrade your source, then add a 282 later.
scubafink posted:
I guess that now your best bet could be to sit down and enjoy your system for a while.
Or maybe you could kill two birds with one stone with a s/h 272, adding a PSU later.
M.
Add Reply
