Sarum T tonearm cable
lyndon posted:
anyone amongst us had any experience of this ??
and the difference between slim and reference, other than the £400
lyndon
i bought recently the chord signature tuned array for my sme5 arm, and find it very good. No brightness or edginess,  soft and fluent, dynamic too. very natural in one world. I imagine the sarum t is a big step over mine...but with the same natural sound.
Plonked the sarum super array in tonight
i was hoping for lots but kind of expecting to put my bats ears on and spot little differences
i was wrong on both
this isn't a subtle upgrade, it's at least or if not more than my journey of 3 x sarum speaker cables
its early days yet, these things tend to enjoy a couple of weeks to get all the electrons facing the right way
first off, there's more of everything again, the extra bass is perhaps most noticeable along with a greater sense of realism
another big one is the level of micro detail being retrieved, this has a massive impact on the overall picture
lyndon
lyndon posted:
i was wrong on both
lyndon
i wonder what would be better: kandid cartridge( made by lyra) with sarum t tonearm cable or lyra etna?   same cost for the two.  I would say etna, but who knows...
Funny you should say that, many years ago, back in the days of the Arkiv I did think of changing to a Lyra Titan ( now is still sold as a Linn Kandid )
at the moment my cartridge is only 1 year old so the cable makes more sense although next time round I'm thinking on the lines of Atlas or possibly Etna
lyndon
I did a Linn Akiva / Sarum Tuned ARAY on Urika v Linn Kandid / Linn Silvers a while ago. The prices don't stack up as such but the cost to change to STA or Kandid were similar.
I didn't actually go for either at the time - but it would have been a difficult call.
Chris
its my understanding that's there's a considerable difference between Sarum tuned and super array
the super array is something very special but it can only deliver what is fed into it
the Akiva is very good but I would think logic dictates a kandid or above before £2k+ for a tonearm cable
the same principle applies across the rest of the components
i certainly wouldn't be doing a full loom sarum super if I still had the briks
my plan after the cables is to replace the preamp - there is only 1 choice
then the same with the power amps, once again only one choice
when it comes to replacing the kandid I will be looking somewhere higher up the Lyra range than the Titan
lyndon
lyndon posted:
Chris
lyndon
i don't know what is your choice to upgrade the phono amp. For me it would be tom evans groove srx, or pass labs xp25 for solid state.  For tube, perhaps conrad johnson tea1,  audio research reference 3, or ypsilon phono( but too expensive).
lyndon posted:
Didn't mention the phono amp
the pre amp that I will be upgrading to is 552
lyndon
i read too quickly....For myself, on my experience, the phono preamp upgrade is the most crucial and with the best impact on sound quality. i talk for myself. but i am not in the subject here, i know
How are you getting on with the cable now Lyndon? I'm very interested.
I'm currently using a tonearm cable made up of £2.00 a metre Van Damme cable with my Gyro SE, SME IV with Ortofon Quintet Bronze, Rega Aria, Chord Solid interconnect into 552dr/300dr. Yes you guessed it, the NDS has shown my vinyl replay to be lacking a bit lol.
When I had it connected to a Superuniti it sounded fine but the more I've upgraded my Naim boxes (and the more the 552 opens up) the less I'm listening to vinyl so I need to bring it into line.
I'm going to do the tonearm cable first and am seriously thinking of trying the Sarum T as a first step.
Do you think I will hear a difference?
Drewy posted:
drewy,
i went recently from van den hull stock sme5 cable to a chord signature tuned array phono cable:  it gave me more fluency, details and open soundstage : about 900GBP.
I would suggest you this cable with a better cartridge, like the lyra delos, for about 1100GBP.
This cable with this cartridge is the total cost of the sarum t phono cable.  It will boost a lot your vinyl replay, more than a sarum t on your present cartridge i think.  I may be wrong but i am quite sure.  For myself i would do that ....
Thanks for the reply. The thing is I reckon I'll go better than a Delos anyway. I like nice big steps rather than smaller ones losing money along the way which is what I've done with the main system components.The Quintet was bought to get me up and running and the old Chord Solid interconnect was one I found in the loft, it held its own very well when I had the SU. The tonearm cable I have came with the SME IV (it was cheaper to buy the arm that way). The damn thing doesn't even fit right (it's a straight din plug that fouls the turntable).
A fine analogue set up doesn't come cheap when you have a top of the range streamer.
Drewy posted:
i understand what you say, you can make bigger jump with more expensive cartridges, phono cable and phono preamp too.  But a good balance in components is also important.   For example i would not put personally a lyra etna on a gyrodeck table, but it is possible for sure.
As for my suggestion, in your system, i would prefer a delos cartridge and signature tuned array phono cable than a chord sarum t for the same money as these two components.
I just wanted to share my point of view,  because you were asking about the sarum t ....But i am not you and you will probably take different options...
Hi Drewy
im getting on just fine with it
just for the record it's a Super Sarum not a T, my original question was regarding the T as I didn't expect to find a S/H tonearm cable
i know the T stuff has taken these already spectacular cables to another level but the £1600+ saved would be better spent towards a 552 right now
unfortunately I don't have unlimited resources, it would be chord music full loom if I had and a music on the kettle as well !!
after a lot of effort changing the cables over, ( the Mana reference shelf does a good job of doubling up as an LP12 jig)
the new cable took my sound to another level straight from the off, most notably-:
the treble had much much more detail without over emphasis on itself so the tonality wasn't brighter just more detail
the bass was deep down lower than before, it was already pretty damn low, this just opened up some new frequencies - I'm using DBLs here. I'm not sure if all speakers would pick this up DBLs go deep deep deeper down than most.
then we have the micros, the very small bits that we never knew existed before, every record no matter how familiar now has things I've never heard before
lastly. The sense of realism of the instruments, upgrading the supercaps from olive to DRs had a similar affect
the above 4 together provides a whole that is much greater than the sum of the parts
of all the cable upgrades ( I have an active 6 pack so plenty of cables to upgrade) this is by far the biggest, moreso than all 3 pairs of speaker cables
think my system is really crying out for a 552 now, wouldn't want to do the 3 500,s til that's in place, there's also the 6 din - xlr cables, may need to think outside the box on this one
lyndon
Hi Lyndon.
Great response, thanks. Sorry I was confusing the thread title with what you are actually using but that doesn't really matter.
Whatever happens i'm pretty sure this £2.00 a metre tonearm cable is holding things back, if it's not then there's a lot of people wasting a lot of money. Anyway upgrading anything else and keeping this thing would be pointless. I'll be looking at starting here I think in the autumn when I start spending a lot more time indoors.
Likes (0)
