Setting Up The Muso
I recently bought the Muso and am currently awaiting delivery of an Oppo UDP-203 and Samsung 55" QLED TV which is the model line with the near invisible cable.
This TV has a one connect box which you plug other devices into rather than directly to the TV.
I just wondered how best to connect everything to the Muso to get the best out of it and the Oppo.
Any suggestions / help greatly appreciated.
Original Post
For flexibility, you could connect the Oppo to the QLED  One Connect box via HDMI and then connect the One Connect box to the Mu-so via optical cable - this would allow any source connected to the One Connect to play through the Mu-so.
If however you want the best audio from the Oppo, I’d connect it directly to the Mu-so (via optical).
Also, remember that the Mu-so is stereo only, so whatever is connected to it needs to be set to PCM sound.
Likes (0)
