Qobuz
Posted by: tonycurran1 on 30 July 2017
Hi I have just bought a years subscription to Qobuz Hi-Fi sublimes+ services
cant work out how to get it from my PC to my NDS
they are all connected wired on the same network
do I need to download a app to my iPhone/iPad
thanks for any advice,
cheers Tony.
Hi
I think this is not simple as the NDS does not have chrome cast or Qobuz built in.
I bought a Qobuz subscription for my Linn Klimax DS as it does have Qobuz built in.
I was able to get Qobuz streaming to work on my on my Oppo BDP 105 which does not have Qobuz built in by installing BubbleUPnP Server on my QNAP NAS so I think you have to do something similar but that depends on what other hardware you have .
Sorry that I cannot tell you exactly what to do but I think you should look into how you can use BubbleUPnP Server with your setup, either server or computer.
Ian
tonycurran1 posted:Hi I have just bought a years subscription to Qobuz Hi-Fi sublimes+ services
cheers Tony.
some members have connected chromcast via optical digital to their 272. So i guess it will work with the nds. As for sound quality i don't know.. Why do you prefer qobuz to tidal, if i may ask? For myself i prefer streaming from my unitserve, cd rips or downloads from qobuz or other sites, i find the sound quality is better than direct streaming from tidal.
But i would be curious to experiment qobuz streaming with my nds too.
You can use the upmpdcli renderer (e.g., running on a Raspberry Pi 3) to SPDIF stream Qobuz, Tidal and Google music to your NDS. You will need a USB->SPDIF bridge or a Hifiberry Digi + Pro connected to the Pi. There are also other viable approaches, see, among others:
https://forums.naimaudio.com/to...roon-with-nds?page=1
cheers Tony.
I use Bubbleupnp Server installed on my Synology NAS and that allows me to stream it to my NDX. The Naim app doesn't see Qobuz but I use Linn's Kazoo app (Lumin is good too) to control it. Works really well.
Can be installed on Windows as well https://www.bubblesoftapps.com/bubbleupnpserver/
I use also bubbleupnp. For me the best way to do it.
